Fried Transistor...
cygnusx1
So I got the L28ET urbo swap running well in the '77. I spent a good part of the day wrapping up harnesses, routing and tucking wires. I buttoned up the electrical portion of the job and decided to check the running voltage at the coil transistor as a final measure. With the car running, I probed the positive lead and measured 13.4 volts, and just then, my butterfingers took over. The probe of my multimeter slipped from the post and jabbed the across to the other post on the transistor. The car instantly shut down and won't spark anymore. I assume I fried the transistor. I still get ign+ 12volts to the transistor, but no life from the coil and no tach signal anymore. The injectors might still be firing, I think.... The ECU still turns on and I tried another ECU just in case, but it made no difference.
By jumping 12v to the other post on the transistor, would my "fried transistor" guess be correct?
Edited by cygnusx1
the small yellow wire fires the transistor by driving it to ground.If you connect a led to v+ and the other side to the yellow wire it should flash while cranking.If you have to you can use an early 4 pin gm hei chip to replace the transistor.or a bosch ignitor .I sold all of my old zxt stuff .
Edited by randy 77zt
I'm pretty sure the transistor is shot. I have another one I'm picking up tomorrow. I can't imagine anything else is damaged...I hope the dizzy didn't take a hit too. :blink: Basically, I accidently jumped 12v over to the spade that has a wire going back to the ECU for firing the coil.
Edited by cygnusx1
  • 1 month later...
