CArFAn Posted October 6, 2011 Share Posted October 6, 2011 (edited) I worked on the 240z w/7mgte and for some reason im not getting any power to or from the cps. I dont know if there should be either?? I have power to the coilpacks, ignitor, ecu and injectors. What controls power to the cps and if you know the exact wire color and location would get you a interwebz cookie. While cranking i get like .2v-.5v from the blue wire on the cps. Anyhelp would be really helpful. If i get it running i promise pure chaos tire shredding videos. Also posted on supraforums and someone asked "Check the wiring for breaks and make sure the ecu is powering on" My response: Ecu has power tested with test light and multimeter. At pin IGSW which from what i read is the power wire for the ecu. As for cracks in the wiring id have to unwrap the harness tomorrow and check. Edited October 6, 2011 by CArFAn Quote Link to comment Share on other sites More sharing options...
CArFAn Posted October 6, 2011 Author Share Posted October 6, 2011 Can anyone go out to their car that has a 7m with a test light or multimeter and let me know which color wires from the cps are suppose to be hot and if using a multimeter what voltage it has to it. Quote Link to comment Share on other sites More sharing options...
CArFAn Posted October 6, 2011 Author Share Posted October 6, 2011 Hey i got spark BIG THANKS TO KARL for helping me out via pm. This guy deserves a medal or something im am effin jumping around right now. Quote Link to comment Share on other sites More sharing options...
