timing marks
duragg
L28 with stock single row pulley only driving an alternator. Inspected pulley and it looked fine when I installed 3 months ago.
Checked timing yeaterday and it is not where I THINK I left it. It was retarded to zero initial.
Either I screwed up the last setup.
Or it moved.
Question: if the thing slips because the rubber is going bad, will that make timing appear suddenly advanced or retarded?
I tried thinking it thru, pulley slips back compared to crank. But my brain locks up when I try to figure what a timing light would show.
It will most likely it will be retarded if your pulley moves relative to the hub/crank. Have you checked whether your distributor moved? Can you get it back to where you had it by turning the distributor?
You can verify if the pulley spun by putting #1 at TDC on compression stroke. The timing mark should be on "0" timing mark.
Edited by rossman
Yes I moved the Dizzy and reset the timing just fine and the RPMs responded and the engine power came back.
Since I last set the timing we reindexed the cam and I have had the cap off several times.
I may have just not set it where I though I set it last time.
With just an alternator would that be enough load to move the pulley? At 7k rpm I suppose.
I will check the TDC mark against real TDC.
Those fancy pulleys are not very expensive, probably a good idea regardless.
