74 260z ignition cylinder removal ?
I would try drilling it with a drill smaller than the pin. It will likely grab the pin and try to turn it as some point during the drilling. You might be able to pull it out with the drill at that point. If the drill does not pull it out you can try to thread in a small sheet metal screw and pull it with the screw.
