ianboo Posted November 15, 2011 Share Posted November 15, 2011 Hello I have a L28E inside of my 280zx. However I am looking forward to putting a turbo on the L28, since the 280zx is not a stock turbo what conversions will I have to do? Also will this turbo specs work on the L28 with minimal conversions? So basically what conversions do I need to do to a 280zx to put a turbo on an L28 and is this turbo compatible? t3 Turbo: T3T4 turbo charger .48ar Intake: 3 inch Inlet: 2 inch Compressor trim: .50 Compressor Wheel diameter: 50.16 / 76.84 Turbine Wheel diameter: 45.74 / 62.86 Exhaust Trim: .48ar Turbine flange type : T3 flange Down pipe flange type: 4 bolt flange Cooling type: oil cool only Horsepower rating: 325-350hp Will this turbo work on my l28 in a 280zx and if so what conversions will i need to do? Thank you so much!!! Quote Link to comment Share on other sites More sharing options...
NewZed Posted November 15, 2011 Share Posted November 15, 2011 Here's a couple of informative threads - http://forums.hybridz.org/index.php/topic/38461-240z-260z-280z-turbo-swap-guide/ http://forums.hybridz.org/index.php/topic/50208-the-ultimate-l28et-guidewhat-you-need-for-350whp/ Quote Link to comment Share on other sites More sharing options...
