Homemade ITB's for an L6
kolonelklink87
I have a half finished ITB manifold using ford 300 I6 truck twin throttle bodies. They are 40mm (302 truck motors got 46mm, and 460 got over 50mm) diameter and have all sorts of nifty little ports for attaching vacuum lines and stuff built into them! My plan for the fuel injectors was to build a rail across the top of them and have the fuel spray directly down them, with a plenum built over them.
I have been side tracked the past couple of years with buying a hou8se, building a garage, yadda yadda yadda, but now that my garage is done, I will have to jump back into the project! Thanks for the inspiration!
