Stock and aftermarket injectors and stock fuel pressure vs "standard" pressure
FricFrac
Question about the L28ET injectors. Since they run stock at 35.3 PSI rather than the "standard" 43.5 PSI and they are rated at 259cc - is that at 35.3 PSI? Also would that mean that comparing them to most aftermarket injectors that are rated at 43.4PSI they would actually be 285cc injectors (@43.5PSI)? Also if you are installing 440cc injectors on a stock system they are actually running 402cc @35.3 PSI? So in MS you would need to configure them as 402cc injectors if you are running them on the stock regulator?
YES! You used the injector calculator; flow rate vs fuel pressure? Then Yes! type in 402@ 36....
