duragg Posted December 4, 2011 Share Posted December 4, 2011 (edited) Picked up my R200 CLSD 4.375. Took it apart of course... Will upload the remainder of the pictures tomorrow. It has 3 internal and 3 external tabbed clutch pads on each side. I think this is good? Stne simple Edited December 6, 2011 by duragg Quote Link to comment Share on other sites More sharing options...
JMortensen Posted December 4, 2011 Share Posted December 4, 2011 (edited) This is good. The cheesy 300ZXT ones had one drive clutch and a big spacer in there instead. Out of curiosity, what are the ramp angles like and do you have thrust washers on the spider gears? Edited December 4, 2011 by JMortensen Quote Link to comment Share on other sites More sharing options...
duragg Posted December 4, 2011 Author Share Posted December 4, 2011 I will take pics of the ramp. Those are the guides the spider rides in? I didn't see any washers on the spiders but will look at that too and report back. Q; should I bother changing side bearings? They look great. Q2: the side seals are readily avail? From? Q3: do I even bother checking break away? Quote Link to comment Share on other sites More sharing options...
duragg Posted December 4, 2011 Author Share Posted December 4, 2011 Ok, Hybridz back online, SNL is over, things are improving... Does this show the "ramps" These control the expansion of the center based on power and squeeze the clutchpak? Some Spider shots. Not thinking I remember any thrust washers, but they could have been stuck to something. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted December 4, 2011 Share Posted December 4, 2011 Weird. Looks like you have a kind of intermediate diff there. It's not the same one that bjhines has that was sold as the Power Brute which had the thrust washers, but you do have the more aggressive ramps and no spacer like the 300ZXT. 4.38 is probably the Skyline diff and I think those were supposed to be more aggressive, so maybe it shouldn't be that much of a surprise. Quote Link to comment Share on other sites More sharing options...
duragg Posted December 4, 2011 Author Share Posted December 4, 2011 I'm thinking if you break a later R200 you are making TB launches on a big-boy motor and have broken a LOT of other parts along the way. Some more pics of my disassemble. Thought I was going to need a different input shaft but this looks normal I think. Found new side seals at Orielly picking up today with some stub shafts from a DD member. Quote Link to comment Share on other sites More sharing options...
duragg Posted December 5, 2011 Author Share Posted December 5, 2011 Getting like 45 pounds break away (wet). Took the unit apart and allbis in order still. That very first bellville plate with outside ears is funny cause it looks like you carefully center it and then draw the cover down on it- hoping the ears are centered and in their grooves. Holding for guidance and machine a better plate to get a torque wrech on a concentric nut. Quote Link to comment Share on other sites More sharing options...
duragg Posted December 6, 2011 Author Share Posted December 6, 2011 Thanks to JM and Gordon and the others for their help. Got some .005" shim stock which I will cut to make some shims. I believe the shim stock will sit on the outside of the furthest outer plate sandwiched against the case. There is no relative motion between this outer plate and the housing so the shim won't wear, just sit and add preload. Shim goes on top of this plate you see here below Note in the picture above, the holes in the case leave an impression in the plate and clearly there is no relative motion. You can see the outer face of the outer-most plate through the housing (where those impressions were left). When done you will be able to see the shim stock through these holes on both ends. And to complete the overhaul, some new output shaft seals which Autozone had in stock. Tomorrow I will shim and lube and shim again and get to my target Break Away Torque (BAT) with my new handy tool being welded in the morning. Will gladly take more pics while I am at it if anybody cares to see any other specific thing while I have this apart. Quote Link to comment Share on other sites More sharing options...
duragg Posted December 7, 2011 Author Share Posted December 7, 2011 No. All wrong. I grabbed the wrong shim stock- see above. Cut, installed and tested 5 shims which made no difference. Off by a factor of 10. That was ,0005" (half-thou) stock. Beer now. Quote Link to comment Share on other sites More sharing options...
duragg Posted December 7, 2011 Author Share Posted December 7, 2011 Interesting option. Almost fits.. Arbor shims ARBOR SHIM SET - 2.25" ID x 3.25" OD Each ARBOR SHIM SET - 2.25" ID x 3.25" OD contains the following sizes: 0.001" 0.0015" 0.002" 0.003" 0.004" 0.005" 0.006" 0.007" 0.008" 0.01" 0.012" 0.015" 0.02" 0.025" 0.032" 0.047" 0.062" 0.093" 0.125" Quote Link to comment Share on other sites More sharing options...
JMortensen Posted December 7, 2011 Share Posted December 7, 2011 I would just button it back up and run it. 45 lbs is plenty considering you have the more aggressive ramps. Quote Link to comment Share on other sites More sharing options...
duragg Posted December 7, 2011 Author Share Posted December 7, 2011 I couldn't sleep with myself if I did that. I like doing things to excess. Quote Link to comment Share on other sites More sharing options...
duragg Posted December 7, 2011 Author Share Posted December 7, 2011 I can't install the R200 in the car for another week anyways. Still collecting all the other parts. So in the meantime all this is keeping me from breaking something else. Quote Link to comment Share on other sites More sharing options...
