beermanpete Posted February 16, 2012 Share Posted February 16, 2012 (edited) ok so not safe to proportion the fronts, and no way to increase the rear pressure if i bypass the stock proportioning valve?? Bypassing the stock proportioning valve will increase the rear brake pressure. Based on all the comments above it will not be enough however. To solve your problem you need different rear brakes. A larger diameter rotor and/or a larger caliper piston diameter. Another possible solution would be converting to a dual master cylinder setup so you can use a smaller diameter master for the rear. Edited February 17, 2012 by beermanpete Quote Link to comment Share on other sites More sharing options...
1 tuff z Posted February 16, 2012 Share Posted February 16, 2012 You can remove the stock prop valve and that will provide additional rear pressure. You could also go to a more aggressive rear pad or less aggressive front. Next would be larger rear brakes-been there done all that. ok so not safe to proportion the fronts, and no way to increase the rear pressure if i bypass the stock proportioning valve?? Quote Link to comment Share on other sites More sharing options...
