240zBoy Posted January 3, 2012 Share Posted January 3, 2012 (edited) It is two pieces and cant seem to find a way for it to not leak. Original one was one piece but now the two pieces have a good quarter inch of play. Someone please help so I can start this tommorow Edited January 3, 2012 by 240zBoy Quote Link to comment Share on other sites More sharing options...
240zBoy Posted January 3, 2012 Author Share Posted January 3, 2012 On 1/3/2012 at 6:50 AM, 240zBoy said: It is two pieces and cant seem to find a way for it to not leak. Original one was one piece but now the two pieces have a good quarter inch of play. Someone please help so I can start this tommorow Well seems like I need one of these http://www.jagsthatrun.com/Pages/Parts_DATZ_Wat-Temp-Send.html. Think I can jb weld the sensor to the nut for now or will that mess with the readings? I am leaving soon and wont be back home for a couple months so ordering in the mail is something I dont want to do. Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted January 3, 2012 Share Posted January 3, 2012 Not sure what block you have. In my LT1 the sensor went straight in without any leakage and with out the adapter. Now I just need to get it wired in to the gauge. Quote Link to comment Share on other sites More sharing options...
240zBoy Posted January 3, 2012 Author Share Posted January 3, 2012 I decided to put a ring of jb weld inside of the retaining nut near the outer edge. This should leave enough of the sleeve to provide a good ground for the sender. The weld appeared to make a good seal but what do you all think. I also purchased the jtr adapter to put on when it comes for extra insurance. Jb weld is an insulator anyways so I think I should be fine. temp.bmpFetching info... Quote Link to comment Share on other sites More sharing options...
Drewz75t Posted January 3, 2012 Share Posted January 3, 2012 I think my sensor screwed into the adapter, and then into the head. I know they have 2 sizes because I got the wrong one at first. Quote Link to comment Share on other sites More sharing options...
240zBoy Posted January 3, 2012 Author Share Posted January 3, 2012 yes that is how it works but the adapter is in the mail. But I need to get going on this car before I leave and did the above process to have it temporarily work. then I will screw on the adapter. But I later began to wonder if the jb weld will tamper with the ground to the block. I believe I will be fine and can use the temp at which my fans turn on as a guideline as to if it is working or not. Quote Link to comment Share on other sites More sharing options...
