Head Milling & Timing
mpresley
Can someone tell me how milling a head for an L6 affects valve timing and in which direction, too slow or too fast to open, and what the practical effects are?
Milling the head will shorthen the distance between the two sprockets( cam / crank ), thus making it retard the cam from what it would have been if it was not milled ( the tenitonier need to make up the extra slack in the chain, thus rotating the cam anticlockwise)
you may be able to get the timing back to what it was by using a different timing hole on the cam sprocket (most has 3 holes), or do what most people do, 'shim' the cam tower the same amount that was milled.
Nigel
Nigel
Thank you. I will see if the machine shop has material for shims.
