Look at my trigger log
Dadaluma
2012-01-08_03.25.06.csv.txtFetching info...
I am trying to find out why tunerstudio keeps going offline line while cranking and under idle/lload as well.
I am using Nissan CAS 6-1 optical can someone please tell me if this trigger log looks ok, i have no
experience wuth reading these. I added .txt to end of file so forum would let me attach it hope thats
not a problem. thank you
I personally have used the usb to serial adapter that diy sells with no problems. Like Matt said, you have some noise or power problems. Make sure you have power while cranking. You should verify that all your grounds are good, and be sure the sensors are grounded to pins 14-19 on the controller. I personally grounded all my sensors to pin 19.The megamanual says something about the hall circuit sometimes having noise problems. You could check it out and maybe try some of the recommendations? Heres the link about the hall stuff, http://www.megamanual.com/index.html step 50, Also http://www.megamanual.com/ms2/inputHEI.htm Just a few easy things to check before you get too in depth with troubleshooting. Good luck.
Edited by kaito
