dpuma8 Posted January 12, 2012 Share Posted January 12, 2012 (edited) I have read the FAQ on the stages of the suspension and I am going for Stage 1. I drive the car on the freeway mostly and never see a track. I bought my 280z with cut stock springs that rub the wheels all the time so I want to do things right. The car is on 15x8 wheels and really low. I want the car lowered but not slammed. I have been reading about strut sectioning but I am not sure i need it because my car never had a stock suspension before so I can't compare. So in the FAQ, it gave us the stages but pictures would have been helpful. I am worried that I will spend $500 and then realize I should have spent the extra money on coilovers and be headache free since the height is adjustable. Any suggestions? Edited January 12, 2012 by dpuma8 Quote Link to comment Share on other sites More sharing options...
surpip Posted January 12, 2012 Share Posted January 12, 2012 (edited) Go coil overs 2.5 ID springs will clear almost anything and are worth the adjustability Ground Control makes a good kit for the Z. Call mark (530) 677 8600. Ask for spring/prising options tell him Ryan sent you. Edited January 12, 2012 by surpip Quote Link to comment Share on other sites More sharing options...
BluDestiny Posted January 12, 2012 Share Posted January 12, 2012 (edited) Just get the tokico illuminas and tokico springs, if you want a lower ride run some 205/50/15 tires. Thats exactly what I was running and here are some shots of it. I was very happy with how it handled. Edited January 12, 2012 by BluDestiny Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted January 12, 2012 Share Posted January 12, 2012 Check your wheel back spacing. Anything with more than 4.75" back spacing is going to rub on coilovers too. Quote Link to comment Share on other sites More sharing options...
dpuma8 Posted January 13, 2012 Author Share Posted January 13, 2012 I have flares so I am assuming I have extra room, correct? Quote Link to comment Share on other sites More sharing options...
surpip Posted January 13, 2012 Share Posted January 13, 2012 (edited) it depends on the spasing of the wheels. too much negative offset you run into problems with your flares too much positive offset you have to worry about your suspention depends on how much offset your running and what width wheels. Flares and coilovers will let you run pritty mutch the widest wheel you would what to on a Z. Offset explained at http://www.tirerack.com/wheels/tech/techpage.jsp?techid=101 Edited January 13, 2012 by surpip Quote Link to comment Share on other sites More sharing options...
