zcrazy_one Posted January 18, 2012 Share Posted January 18, 2012 Hey guys and gals, Looking to purchase a 80055 Powerforce or 90055 Powerforce Plus. It may not be light enough to cause this issue. But I am worried if I install this on my 2.4L, that already has a Fidanza Lightweight flywheel, that it will die when pushing in the clutch or when stopping? Anyone else running these two items together having problems? Thanx in advance. Bryce Quote Link to comment Share on other sites More sharing options...
Tony D Posted January 19, 2012 Share Posted January 19, 2012 Absolutely unfounded problem if your idle mix is properly tuned. I have a clutch that (WITH flywheel) weighs a TOTAL of 15# (your Findanza and Clutch assembly is closer to 30#!!!) and I don't have that issue. Stalling is a mixture issue, not a rotating mass issue. Quote Link to comment Share on other sites More sharing options...
zcrazy_one Posted January 19, 2012 Author Share Posted January 19, 2012 On 1/19/2012 at 12:18 AM, Tony D said: Absolutely unfounded problem if your idle mix is properly tuned. I have a clutch that (WITH flywheel) weighs a TOTAL of 15# (your Findanza and Clutch assembly is closer to 30#!!!) and I don't have that issue. Stalling is a mixture issue, not a rotating mass issue. Thanks Tony D, that's the answer I was looking for. Bryce Quote Link to comment Share on other sites More sharing options...
