Is this a Good buy @ $2600?
I would double check that. If you wipe out a cam lobe then the lobe/lifter metal will eat up the engine bearings. I measured a set of vortec heads a few years ago and the retainers hit the valve stem seal at 0.420".
http://www.ryanscarpage.50megs.com/combos1.html
Check out combo 73. Close to your build with a little bigger cam.
Can down load the site summary as an excel spread sheet.
Kool I'll double check the lift for a stock vortec head.
Changing to Vortec heads will require an intake manifold made for the Vortec heads.
Yup but i can get an intake for $150 shipped and that would be a pretty cheap 40hp.
Edited by logan1
