78zstyle Posted January 26, 2012 Share Posted January 26, 2012 I am purchasing a 14mm pallnet fuel rail from another remember for a GREAT price,however I have 11mm supra injectors. Can I simply get a bigger o ring to fit into the larger fuel rail? Does anyone have experience with this? Quote Link to comment Share on other sites More sharing options...
Tony D Posted January 27, 2012 Share Posted January 27, 2012 You can get adapters for your 11mm injectors so they properly accommodate the 14mm O-Rings, I believe they were made out of Teflon. Saw them on some injector site somewhere... Quote Link to comment Share on other sites More sharing options...
78zstyle Posted March 11, 2012 Author Share Posted March 11, 2012 thanks tony. for anyone who runs into this predicament, either get the correct fuel rail, or do what I did: Make adapters from aluminum stock and press fit them in with loctite. Quote Link to comment Share on other sites More sharing options...
Tony D Posted March 12, 2012 Share Posted March 12, 2012 The adapters I saw were (if sectioned) 'H' configured, you put your standard 11mm O-Ring on the inside, and the 14mm O-Ring on the outside, you could do one end, or the other...or both depending on what you had and where you were putting it. The ones I saw were either nylon or teflon. Quote Link to comment Share on other sites More sharing options...
