quickgt Posted January 31, 2012 Share Posted January 31, 2012 Ok guys, I know this topic has been beat to death and finding a clear cut answer with the search engine has beaten me to death too. Here goes. Im running a 96 LT1 in my 280Z. Im going carbureated. I only want to use the crank and the alternator. Im using a electric water pump so thats no big deal. My question is, has anyone found a bracket that will work on a 280Z that will allow you to run an alternator/crank pulley only? God I hope so. Im dead set on a carb setup because A) Its a lot neater in the engine bay. Ive already got everything to do it (carb, intake mani, dizzy, and opti hole plug and so on). Thank you so much. BTW HYBRIDZ ROCKS Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted January 31, 2012 Share Posted January 31, 2012 I've heard you can use a vette lt1 bracket and relocate the alt down low so no powersteering a/c. Quote Link to comment Share on other sites More sharing options...
leopard_125 Posted February 4, 2012 Share Posted February 4, 2012 Ok guys, I know this topic has been beat to death and finding a clear cut answer with the search engine has beaten me to death too. Here goes. Im running a 96 LT1 in my 280Z. Im going carbureated. I only want to use the crank and the alternator. Im using a electric water pump so thats no big deal. My question is, has anyone found a bracket that will work on a 280Z that will allow you to run an alternator/crank pulley only? God I hope so. Im dead set on a carb setup because A) Its a lot neater in the engine bay. Ive already got everything to do it (carb, intake mani, dizzy, and opti hole plug and so on). Thank you so much. BTW HYBRIDZ ROCKS I got a billet part from Summit. some thing like PSR or the like i can't remember right now the exact name. but it was a quality part and worked with my electric water pump with a little modification. I'll be going to the car storage later to get the Z out and look for a name on the part if you like. Quote Link to comment Share on other sites More sharing options...
quickgt Posted February 6, 2012 Author Share Posted February 6, 2012 Please do Leopard. Im getting everyting together to do the swap. Got the JTR swap manual to help. I cant wait. Thanks for the answers. Quote Link to comment Share on other sites More sharing options...
wheelman Posted August 29, 2012 Share Posted August 29, 2012 I ran with just an alternator for a while. To do it I fabbed a bracket that included 2 pulleys to delete the AC and PS. Later I installed power steering so I wacked off the PS delete part of the bracket so now it's just an AC delete setup. At the time I installed the first setup I got grief because it wasn't a pretty chromed/billet part but the car is a race car so I really didn't care that it wasn't "pretty". Here is a picture of the original setup. Quote Link to comment Share on other sites More sharing options...
_Donovan_ Posted October 7, 2012 Share Posted October 7, 2012 I wish I saw this post a while ago. That A/C delete set up is perfect. I made something "similar" that more or less works. I will have to search for this though. Quote Link to comment Share on other sites More sharing options...
