vega Posted March 18, 2012 Author Share Posted March 18, 2012 tq breaks stuff not hp unless the rpm is too high. its a balancing act. Quote Link to comment Share on other sites More sharing options...
rsicard Posted March 18, 2012 Share Posted March 18, 2012 Focus on the point of the post. Quote Link to comment Share on other sites More sharing options...
vega Posted March 19, 2012 Author Share Posted March 19, 2012 I am not too worried about breaking anything. Sudden power increases tend to break things, like tq. The custom cam I am having ground will have a very very flat tq/hp curve. Also because it is a smaller motor it will run better with it setup that way at idle. I am running a higher lsa and icl. Quote Link to comment Share on other sites More sharing options...
ttsbc280z Posted May 22, 2012 Share Posted May 22, 2012 (edited) to give you an idea of power to run 11's, i can run a pretty consistent 11.5 at 120 ( pegged out on the rev limiter in 3rd) 3.7 lsd r200 on pump gas on 6 psi of boost on my very mild 350 and th350 trans with sloppy stall (4000 stall blowing through to 5k under full power). I figure the motor makes an honest 300hp, and close to 420hp on 6 psi it has a mild cam ported 487 casting heads, flat top pistons and holley strip intake. twin t3/t4 setup. This is not a very efficient setup. The car would go much faster with a smaller stall and longer gear. If you had an honest 450hp with the correct gear ratio / tire choice / stall it would go mid to low 11's, street tires? probably not. heres a vide of an 11.7 pass the other weekend. Edited May 22, 2012 by ttsbc280z Quote Link to comment Share on other sites More sharing options...
