whats needed for efi?
75zcar
I have a 75 280 that I have been peicing together. I found a 260 motor for the car. The problem is that I don't have any engine wiring, fuel or ignition setup. Or even an intake mani. I have located someone with a wrecked z willing to part it out (78? 280).
My question is what all do I need to get? This is the list I have came up with...
-intake manifold
-throtle body
-ecu
-fuel rail
-injectors
-fuel pump
I know there are things I'm forgetting which is why I am here. I have tried searching for a complete list with no luck. Any help would be great. I need to get this car moving under its own will in the first time in likely a decade.
Have you considered throwing some carbs on it? Another option is to build a Megasquirt setup, if you're starting from scratch anyway... Otherwise, if you dont have the FSM's and the Fuel Injection Bible, those have everything you would need.
Here's everything:post-12144-083073100 1330620558_thumb.png
Intake manifold, Throttle body, Injectors, Resisters for the injectors, To Run Megasquirt, Fuel pump, if yours is no good, a G.M. Intake airtemp sensor, 240sx Throttle position sensor or any mid 90's Nissan TPS Sensor, Wideband o2 sensor and gauge. You will have to decide if you want to use a Distributor or A Crank sensor of some type to get spark.
I don't know much about Megasquirt; I have a SDS system that I'm going to install once I get some money, so my (limited) knowledge on aftermarket EMS's is related to SDS. Based on that, you would probably need:
-Fuel pump
-FI intake mani/ fuel rail/ pressure regulator/ injectors
-Map sensor
-240sx or other potentiometer type throttle body
-IAT and Water Temp sensors
-Injector harness
Probably pretty similar for Megasquirt.
