94 300zx calipers mounted on 73z
Just wanted to share some progess photos of my 5 lug swap and rear disc brake set up with everyone...The car is a 1973 240z with techno toy tuning rear r230 swap with 5 lug conversion using the 94 300zx wheel hub, caliper, and some ichiba extended studs. I managed to also mount the stock ebrake cables along with the inner shoes for parking/or power sliding(giggle) purposes....
Yeah, the swap was really time/energy consuming. I had to track down/order the hub, studs, ebrake cables, calipers, bolts for calipers, axle nut size 36mm, rotors etc....so definitely time consuming. I would suggest if you could get the whole entire complete rear knuckle from the 300zx the better.
If I can ask ...what was the ebrake cable off? and how did you attach it to the standard ebrake lever
Cheers
Ian
