DPG Posted March 12, 2012 Share Posted March 12, 2012 As the title says, I have a set of 45mm intake valves that but am unsure if I should go with a 35mm exhaust valve, or the 38mm exhaust valve from Arizona Z Car. Has any one done this 45/38 set up on a head before and seen positive results? I will be installing these on an E31 head that will go on an L28 block bored .040 over, with flat top pistons. Thanks for any help guys! -David Quote Link to comment Share on other sites More sharing options...
TRIPLZ Posted March 14, 2012 Share Posted March 14, 2012 As the title says, I have a set of 45mm intake valves that but am unsure if I should go with a 35mm exhaust valve, or the 38mm exhaust valve from Arizona Z Car. Has any one done this 45/38 set up on a head before and seen positive results? I will be installing these on an E31 head that will go on an L28 block bored .040 over, with flat top pistons. Thanks for any help guys! -David try posting in this forum: http://forums.hybridz.org/index.php/forum/33-engine-components/ Quote Link to comment Share on other sites More sharing options...
johnc Posted March 14, 2012 Share Posted March 14, 2012 Its been done: Quote Link to comment Share on other sites More sharing options...
DPG Posted March 16, 2012 Author Share Posted March 16, 2012 try posting in this forum: http://forums.hybridz.org/index.php/forum/33-engine-components/ Thank you Quote Link to comment Share on other sites More sharing options...
