k204drek Posted March 23, 2012 Share Posted March 23, 2012 Like the title says does any one have any pictures of there v8 swaps with a muncie 4 speed installed. Quote Link to comment Share on other sites More sharing options...
ttsbc280z Posted May 22, 2012 Share Posted May 22, 2012 i installed a saginaw one time, it fit like ****, had to jimmy rig the shifter, beat on the tranny tunnel ALOT it was offset wayy to far to the drivers side the way it hangs of the side, however the t56 fit much better Quote Link to comment Share on other sites More sharing options...
Jim T Posted October 15, 2012 Share Posted October 15, 2012 Like the title says does any one have any pictures of there v8 swaps with a muncie 4 speed installed. I just purchased a 240 with a 4 speed Muncie. I will try to post pictures in about one week. Car is currently getting new clutch master and slave installed. I can tell you the previous owner had a Pete Jackson Racing front drive distributer installed so the engine could sit further back and shifter is in stock position. This is a old install and was done in the late eighties. Car is in need of TLC but when it is up on hoist next week will see what I can do for photos. Quote Link to comment Share on other sites More sharing options...
bigbore468 Posted October 18, 2012 Share Posted October 18, 2012 Like the title says does any one have any pictures of there v8 swaps with a muncie 4 speed installed. Sorry no pics, but can tell you what we did to make it fit with the shifter located in the stock location. We used a Hurst Super Shifter; this has straight shift arms, and lengthened the shifter bracket and shifter arms to get back enough to align with the stock shifter hole in the tunnel. Then made an offset stick to get it through the stock shifter hole and boot. You may have to clearance the tunnel on the drivers side, but not to the extent that requires cutting and patching. I've since gone to a T5, and still may have that set up laying around somewhere. Also recall others discussing this a while back, and there were pictures in that post too. Good luck. Quote Link to comment Share on other sites More sharing options...
