Andrew Bayley Posted October 9, 2001 Share Posted October 9, 2001 Four Bolt Main Caps... This is the "splayed" version where the outer bolt of the two is angled away from the crank. -Andy [ October 09, 2001: Message edited by: Andrew Bayley ] Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted October 10, 2001 Share Posted October 10, 2001 How exactly do you tell the difference between a 2 and 4 bolt chevy 350? I have the pan off, cuz well, I did something dumb Anyway, there are two bolts on each side of the crank. Does that mean it's a 2 bolt? If someone had a pic of a 2 vs 4 bolt, or if there is one on the web, it would be greatly appreciated. Thanks a million sean Quote Link to comment Share on other sites More sharing options...
Guest Tht1KSguy Posted October 10, 2001 Share Posted October 10, 2001 yep it's a 2 bolt... a 4 bolt will have 4 bolts on each of the #2, 3, and 4 main bearing caps Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted October 10, 2001 Share Posted October 10, 2001 so the four bolt has 8 bolts per cap? then. OK, sounds good. sean Quote Link to comment Share on other sites More sharing options...
Tim240z Posted October 10, 2001 Share Posted October 10, 2001 No, the four bolt has 4 bolts for the 3 middle caps. Tim Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted October 10, 2001 Share Posted October 10, 2001 so I do have a 4 bolt main then? I'm really confused. Does anyone know of a pic on the web? sean Quote Link to comment Share on other sites More sharing options...
Guest Tht1KSguy Posted October 10, 2001 Share Posted October 10, 2001 nope, 4 bolts per cap.. 2 on each side of the crank.. sorry i misread your first post you have a 4 bolt block. I misread 2 bolts per side as 2 bolts per cap. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted October 10, 2001 Share Posted October 10, 2001 oh, ok, now it's all clear. Thanks for the info guys sean Quote Link to comment Share on other sites More sharing options...
