Guest tom sixbey Posted March 28, 2002 Share Posted March 28, 2002 gas is gonna get expensive again. I know where i can get 100 octane low lead aviation gas for less than 2 bucks a gallon - will leaded gas have any adverse effects on the fuel injectors? Quote Link to comment Share on other sites More sharing options...
74_5.0L_Z Posted March 28, 2002 Share Posted March 28, 2002 Unless you are running high compression or boost, you don't need anything better than 93 octane unleaded. I have 9.5:1 compression and run 16 degrees initial timing(36 total) without any problem. The leaded should be no problem with the injectors, but the O2 sensors won't like it. I assume you are not runnings catalytic converters. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 28, 2002 Share Posted March 28, 2002 I don't think the injectors will mind it as much as the oxygen sensor will, I'm not sure but I think I read someone here saying that the lead would foul the oxygen sensor after a bit of use. Considering how sensitive they are to even carb cleaner/solvents it wouldn't surprise me. Good price on Av Gas though considering its about 1.80 for premium unlead here at the moment. Regards, Lone Quote Link to comment Share on other sites More sharing options...
Tim240z Posted March 28, 2002 Share Posted March 28, 2002 The lead will definitely foul the O2 sensor. You will have to get a bypass wiring harness to fool the computer into thinking that there is a sensor there. This is a major problem with 'grey market' imports of cars from the USA to countries with leaded gas. Tim Quote Link to comment Share on other sites More sharing options...
Guest tom sixbey Posted April 3, 2002 Share Posted April 3, 2002 thanks for the info guys... i forgot all about the O2 sensor. Darn. Quote Link to comment Share on other sites More sharing options...
