1982 280ZXT - rear end seal for gearbox
darkzebra
Courtesy Nissan in Texas tells me Nissan no longer stocks the rear end seal for the 1982 280Zx turbo car 5-speed gearbox - which I think is a Borg & Warner?
Anyone has any idea where I can get a replacement?
Also, Nissan wants an arm and a leg for the little rubber? connection between the oil-pan and the turbo drain-pipe. Is there any other less expensive replacement i can use?
Rock Auto has the rear seal for the T5 only without the metal flange that covers the yoke. Less than $6 IIRC.
For the hose between the oil pan and turbo drain tube, I just used some heater hose I had left over. It's been on for 2 years and more than 15k miles with no issues. I had to pull one end off to change the head gasket the other day and the rubber still looked and felt good.
