emeraldlion Posted May 3, 2012 Share Posted May 3, 2012 So the wire I used to go to the neg terminal on the HEI already has a 10k ohm resistor in line. I had seen a the posts saying have a resistor in-line. I have a '78 280z. When I turn the car on the tach pegs 8k and stays. No bouncing or fluctuation. Wondering if I should remove the 10k ohm or place another 15k ohm in line to total 25. this is a double post, I posted this in electrical but no response in 3 days. Wanted to try this before going out and buying a super tach II Quote Link to comment Share on other sites More sharing options...
Leon Posted May 3, 2012 Share Posted May 3, 2012 My 260Z tach did this when it died. Replaced with a 280Z unit (ebay, $25) and all has been good since! Quote Link to comment Share on other sites More sharing options...
emeraldlion Posted May 4, 2012 Author Share Posted May 4, 2012 Thanks Leon. I think I will replace it with an aftermarket unit if that is the case. this gives me the reason to pull it out and check it. Appreciate the input Quote Link to comment Share on other sites More sharing options...
