Cam Sprocket holes 1, 2 and 3
Zark
I have checked my cam timing using an indexing wheel and a piston stop to get TDC, and find that the valve timing is retarded about 3.5 degrees due to chain stretch. I have a Comp street cam, 260 and standard cam sprocket.
My question is do holes #2 and #3 on the cam sprocket advance the cam in 4 degree increments. In other words, #2 hole is 4 degrees advance and #3 is 8 degrees advanced. This is how I interpret the FSM. Am I right?
I have searched this site and found no clear simple answer. Also searched the web and found some contradictory explanations.
