Head casting #s
Pull the valve cover. In between some of the rocker studs. Should be easy to spot unless it is sludged up. The last 3 digits are also cast on the underside of one of the intake ports if the heads are off, but be careful since several heads had the same last 3 digits but different casting numbers.
