stony Posted May 14, 2012 Share Posted May 14, 2012 Can someone please explain the pic below in stupidese? I had this kit installed on the Z several years ago and when i took it out i completely disassembled it not marking where the hoses went. The piece that screws on to the block is not marked and i cant remember which one is in or out. This is not my kit just a pics i found on the net of the kit i have. Also if someone has a better idea on how to get oil press and temp i'm all ears. the stock oil cooler is gone and my filter screws directly onto the block. Was going to try and shoe horn this kit into the orange Z just so i have a place for put the senders. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
djz Posted May 15, 2012 Share Posted May 15, 2012 Hoses coming out of the filter mount will go to the filter block adaptor, they should be marked with something, can't remember what but my HKS kit is. If not you might have to trace which port on the filter mount matches which port on the filter block adaptor, you've got a 50/50 chance of getting it wrong Quote Link to comment Share on other sites More sharing options...
stony Posted May 15, 2012 Author Share Posted May 15, 2012 The adapter that comes off the block is not marked. But i did find out that the center fitting is oil out and the offset one is oil in. Quote Link to comment Share on other sites More sharing options...
