Guest jens Posted February 8, 2002 Share Posted February 8, 2002 Is there others than the 79-? mustang that use the rearsump pan. Like gran torino or ranchero. Is there anyone who knows a link to a ford webpage with 302 block and head codes Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 9, 2002 Share Posted February 9, 2002 don't forget some ford trucks came with rear sump and hydraulic throwout bearings Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 9, 2002 Share Posted February 9, 2002 It would be great to find a rear sump oil pan, either after market or bone yard. This would make for easer r&r. All the pans I've seen for sale have been front sump or double humpers..I've only looked in Summit and Jegs though. I'm about to take a double hump pan and cut holes in it and reweld another sheet across the bottom and sides to make a big rear sump. Brian Quote Link to comment Share on other sites More sharing options...
Guest jens Posted February 9, 2002 Share Posted February 9, 2002 I have found som useable links. www.oemfordparts.com sells the dualsump oilpan conversion kit for 302w and 351w. This is the best engine code page i could find http://www.cehighperformance.com/ford_block_car_codes.htm This one has good information about the 351w www.geocities.com/8351 In Which cars can i find the 351w 2v. Quote Link to comment Share on other sites More sharing options...
Trevor Posted February 10, 2002 Share Posted February 10, 2002 Early Ford Econoline vans ('69-7?) with the short nose have a rear sump oil pan. Looks like a Chevy pan. Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted February 10, 2002 Share Posted February 10, 2002 Where is the oil pump on those vans? The only reason for the double hump pans is to clear the oil pump in the front. Oil pump is in the front. I'm going to fab a new cross member for the steering rack and use a full sumped pan like tube chassis cars use on my 351 powered Z. Quote Link to comment Share on other sites More sharing options...
blueovalz Posted February 10, 2002 Share Posted February 10, 2002 I believe all the SBF oil pans will either be double hump, or front sump, but no rear sump only. The oil pump on all the SBF engines is up front, so the small hump on the double humps is for the pump itself, then the pickup tube is extended so that it picks up the oil in the back larger sump. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 15, 2002 Share Posted May 15, 2002 Any of the Fox-body Fords (T-bird, Cougar, Mustang, Capri, Granada, Fairmont) plus some trucks used the double sump pan. www.fomoco.com has folks that can help you decode engine parts. Ask for Mr. F in the General forum. Quote Link to comment Share on other sites More sharing options...
Mike Mileski Posted May 16, 2002 Share Posted May 16, 2002 I think all early Broncos, 1966-1977, with V-8s (289s until mid-68 and 302s after that) had rear sump only pans. I've owned several and that's what I remember. Mike Mileski Tucson, AZ Quote Link to comment Share on other sites More sharing options...
gene_w Posted May 17, 2002 Share Posted May 17, 2002 I've got a 351W that is marked as having come out of an '82 Econoline, and it's got a rear-sump oil pan. the oil pump is in the front and it just has a long pickup that goes all the way to the back of the pan. Looks like it should drop into my '75 pretty easily! Gene Quote Link to comment Share on other sites More sharing options...
