99 5.7l info
$100.00 is a reasonable price for the engine. The cylinder heads alone may be worth that much. Replace the head gasket and do a leak-down test on each cylinder. You may be surprised that it still has life if it was run with the fuel injection system that DOES NOT wash down oil in the cylinders as carbs DO. It also has a 1-piece rear crankshaft seal and 0.3 TALLER lifter bosses as it is a roller-cam engine.
