240z72 Posted June 9, 2012 Share Posted June 9, 2012 I just got this car going well. It had some bad timing issues and electrical stuff. I got it running well then about 10 mins after running it it started making this noise. you can hear it from the cab. It is loudest on the passenger motor bay. I included a youtube link. Sound is not the best but you should be able to hear it. it changes as i rev it up a bit. Take a look and tell me what you think. Thank you. its like a ticking hissing noise. Quote Link to comment Share on other sites More sharing options...
dexter72 Posted June 9, 2012 Share Posted June 9, 2012 You may be able to narrow down where the noise or noises are coming from. Place your ear on the handle end of a long screw driver and place the other end along the engine, alternator outer case, and trans case. While the engine is running. Check for a blown headgasket since you said the engine had timing issues. Warped exhaust manifold causing an exhaust leak. Quote Link to comment Share on other sites More sharing options...
240z72 Posted June 9, 2012 Author Share Posted June 9, 2012 Hi dexter. Thanks gor the advise. It was late so i just turned in for the night. I will check out a few things and update asap. Thanks again! Quote Link to comment Share on other sites More sharing options...
240z72 Posted June 10, 2012 Author Share Posted June 10, 2012 (edited) Update. I checked my compression and its 135 across all six. And i swaprd out my alternator for a know good one and the sound hasent gone away. Edited June 10, 2012 by 240z7273 Quote Link to comment Share on other sites More sharing options...
240z72 Posted June 11, 2012 Author Share Posted June 11, 2012 Update. I found the source of the noise. It is comming from the oil cooler/ filter housing thats bolted to the motor. Ehat could this be? The check ball? Any imput would help. Quote Link to comment Share on other sites More sharing options...
