k204drek Posted July 21, 2012 Share Posted July 21, 2012 I have 2 volts at my coil. And 2 volts coming out of the dizzy. The car will turn over and over and over and then will hit once then over and over and over. I converted it to HEI module and it didnt change anything. Quote Link to comment Share on other sites More sharing options...
NewZed Posted July 21, 2012 Share Posted July 21, 2012 2 volts is not enough. You have bad connections somewhere. If the engine turns over, you must have around 12 at the battery. Quote Link to comment Share on other sites More sharing options...
k204drek Posted July 21, 2012 Author Share Posted July 21, 2012 I tried hot wiring the coil last night and it did nothing. I tried a new coil today it also did nothing. It has brand new bosch supers in it now but im gonna get some NGK plugs for and retry hot wiring the coil. Quote Link to comment Share on other sites More sharing options...
k204drek Posted July 21, 2012 Author Share Posted July 21, 2012 Ok this is wierd i put a hot wire on the coil with a eye connector tightened it securely and then ran my hot wire to the battery nothing happened. Ok so i bring out the voltaqge regulator and the hot side of my coil tests 0 volts. So i then test my battery it reads 12 volts until i touch the hot side voltage regulator lead with my wire hooked to the hot side of the cool it goes to 0. Is a 280z positive ground or what? Quote Link to comment Share on other sites More sharing options...
k204drek Posted July 22, 2012 Author Share Posted July 22, 2012 Voltage tester not regulator. I figured out that I do have 12 volts at my coil and at my hei module but not coming out of the hei module. Quote Link to comment Share on other sites More sharing options...
NewZed Posted July 22, 2012 Share Posted July 22, 2012 Try starting fluid through a port in to the intake manifold. If it starts, revs, then dies, your problem is probably fuel not spark. Quote Link to comment Share on other sites More sharing options...
k204drek Posted July 22, 2012 Author Share Posted July 22, 2012 I poured seafoam in intake and didnt crank. ONLY BECAUSE I WAS OUT OF STARTING FLUID. Quote Link to comment Share on other sites More sharing options...
NewZed Posted July 22, 2012 Share Posted July 22, 2012 (edited) Deleted. Speechless. Edited July 22, 2012 by NewZed Quote Link to comment Share on other sites More sharing options...
k204drek Posted July 22, 2012 Author Share Posted July 22, 2012 Not sure if i know what that means. Im gonna get a new HEI module for it tommorow and try it. Quote Link to comment Share on other sites More sharing options...
k204drek Posted July 22, 2012 Author Share Posted July 22, 2012 I got a new hei module I have 12 volts going into module but 2 volts coming out of module. Quote Link to comment Share on other sites More sharing options...
