xxxpatsabxxx Posted July 27, 2012 Share Posted July 27, 2012 Hey everyone,  I'm having trouble with my 2nd hand 1971 4 screw SU carbs that I am in the process of rebuilding. They are not yet installed and are currently on my bench.  The Problem  The piston ends up freezing in position when I install it into the carb body and screw on the Bell chamber. It stays closed the worst in the closed position but also stay in the open position when it does get moved.  But  When i place the piston into either the chamber OR the body, it moves freely. Being the guy that I am, I decided to eliminate as many problems as possible so I swapped components (piston, chamber/dome, nozzle, needle) from the front and rear carbs and the problem persisted on only the front carb.  With as many SU carb owners that there are, someone has to have encountered this problem. If not, I'd love a helping hand on troubleshooting.  - So gentlemen, What problems can there be and how can i fix them? - I was thinking it could be the nozzle (but i had that replaced) - Maybe my jet retaining nut is bad? - Warped carb body? - Possibly oversized needle? - Needle offset. (but works with other carb body?)  Thanks for your time,  PatSab Quote Link to comment Share on other sites More sharing options...
xxxpatsabxxx Posted July 27, 2012 Author Share Posted July 27, 2012 i think it might be a combo of the needle size the PO had installed and the new nozzles i ordered from MSA... Quote Link to comment Share on other sites More sharing options...
Leon Posted July 27, 2012 Share Posted July 27, 2012 Remove the needle from the piston and you'll take the needle and nozzle out of the picture. If it moves freely with the needle removed, you'll know for sure that it's a needle/nozzle issue. Quote Link to comment Share on other sites More sharing options...
xxxpatsabxxx Posted July 27, 2012 Author Share Posted July 27, 2012 Thanks leon, it was an issue with the needle, it must have gotten bent on my workbench. Quote Link to comment Share on other sites More sharing options...
Leon Posted July 27, 2012 Share Posted July 27, 2012 Thanks leon, it was an issue with the needle, it must have gotten bent on my workbench. Bingo! Quote Link to comment Share on other sites More sharing options...
