pinion flange question
evildky
Guest Anonymous
Unbolt your drive shaft and measure across the round slight male protrusion in the center of the flange the ujoint is connected to. This is the male part of the pilot flange that centers to the female pilot flange that is connected on the differential pinion.... better yet buy a 2-2-899-1 diff adapter and if does not bolt up to the diff pinion flange ..ya got a 2.00 and then find one the flange adapter fits and I will guarantee it to be a 2.25 inch pilot diameter. I never measured mine just slapped the Neapco 2-2-899-1 adapter flange on the differential pinion flange and clearly saw daylight in all 4 mounting holes with a flush fit. Get the adapter flange cuz you will need it sooner or later.
not as cheap as I thought, the guy that priced me on the phone was not there, I think he quoted me the dealer price ? anyhow it brok down like this:
N2-2-899-1 29.96
Tax 1.80
Freight charge 5.05
Total 36.81
not what I was expecting, but I am guesing freight would be about the same to your door, if this is better than you have found local the name of the shop is Republic Diesel and they can be reached at 1-800-292-5565 they are located here in Louisville, KY
