Guest Anonymous Posted January 17, 2003 Share Posted January 17, 2003 Hello everyone, I'm new here, but I have been monitoring the site for a long time. I was wondering if anyone has tried to convert a Z to Fords 8.8 indy suspension, or a least the diff and cv-axles. Quote Link to comment Share on other sites More sharing options...
denny411 Posted January 17, 2003 Share Posted January 17, 2003 I haven`t heard of anyone doing the swap. I seem to remember someone saying they weren`t as reliable or durable as the standard 8.8. Try a search and see what comes up. Quote Link to comment Share on other sites More sharing options...
blueovalz Posted January 17, 2003 Share Posted January 17, 2003 If this "Indy" rear end is similar to the typical current Ford IRS, then I can say that I've compared dimensions of the ford assembly to hypothetical pick-up points on the Z for the subframe and I've found that the Ford unit is a bit too wide for installation by the typical Hybrider. If I knew I was going to attempt this kind of swap from the get-go, then perhaps the job would not be so intimidating as far as the size difference goes. The 240SX or last generation 300ZX assembly is closer in size to the Z than the Ford unit is. Quote Link to comment Share on other sites More sharing options...
G Gress Posted January 17, 2003 Share Posted January 17, 2003 The cobra boys use them quite a bit, center section, half shafts and uprights from a T-Bird supercoupe. Supposedly the ones with a driver side cv-shaft diameter of 1.2" are the strongest. Factory Five Racing (cobras) has an option for the T-Bird rear that comes with shortened cv-shafts or Moser Engineering will shorten and re-spline for $100. I believe? FFR has a turbo 5.0 running in the 10's with that rear. I like all the ratios and lsd choices for that one. Quote Link to comment Share on other sites More sharing options...
G Gress Posted January 17, 2003 Share Posted January 17, 2003 P.S. T-Bird center sections are cast iron, Lincoln MarkVIII and Cougar are aluminum. Ford is supposed to have a new aluminum center with traction-loc for 600 bucks, but I haven't checked. Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted January 18, 2003 Share Posted January 18, 2003 I just sold a Supercoupe. I was thinking of yanking the diff and axles. 3.27 gears and limited slip. It would make a good ratio for a HybridZ. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 18, 2003 Share Posted January 18, 2003 My dad has a cobra with the sc rear end with shortened shafts it works well It stands up to a 429scj. I dont think the 8.8 in the sc is limited slip so a person should check when buying one . dad had to put it in after. Quote Link to comment Share on other sites More sharing options...
