Crankshaft pulley
You need a gear puller. If you don't have one, your local parts store (Checker/AutoZone etc) usually has a loaner program where you can buy it and return for refund after you're through.
When you reassemble, be sure to use blue loctite on the crank bolt threads.
But I have to ask why you're taking the timing cover off to replace the head gasket...
There are 2 theaded holes in the balancer that are used to remove the balancer. You need a puller tool like this: http://www.harborfreight.com/46-piece-bolt-puller-set-37824.html
Some of the Zs have an accessory pulley screwed to the balancer which uses the same theaded holes needed to remove the balance. If so, remove the 2 screws and the pulley. Then you will be able to remove the balancer.
As Zmanco asked, why are you removing the balancer to R&R the head?
A puller is cheap (harbor freight has them) and works well for pulling the balancer. I really reccomend using one. Prying the pully or pounding on it can mess up your seals, or even bend/crack your crankshaft. it's just not worth the damage for a $10 tool. Make sure you replace the kingpin if it's at all worn. You don't want it to snap and throw off your timing possibly ruining your head. Also, it's money, but Kamari makes a tensioner that's got a bearing on it that is a worthwhile upgrade while you've got the covers off. Maybe replace the chain too if the engine is over 100K miles. oh Ford Viton (f100??) valve seals are a good idea.
