_X_ Posted August 29, 2012 Share Posted August 29, 2012 Hello When I disconnected the transmission I had to disconnect this cable that had a gear on it. The cable connected to the stock 5 speed transmission. Since I will be dropping an ls1 and a t56 in the z I presume that I no longer need this cable. Just wanted to ask what I should do with this cable. Quote Link to comment Share on other sites More sharing options...
SUNNY Z Posted August 29, 2012 Share Posted August 29, 2012 Thats the speedo cable - best I can tell. No, you won't need it. Because the t56 has an electronic speed sensor, or if you did put a different tail shaft on it, it uses a different gear, I'm almost 100% certain. 1 Quote Link to comment Share on other sites More sharing options...
wfritts911 Posted August 30, 2012 Share Posted August 30, 2012 ^ Yup speedo cable, no need for it with the T56. -Will Quote Link to comment Share on other sites More sharing options...
