Oxygen sensor install
Hi everybody,
I'm installing some headers for a couple of reasons. 1) There was a massive exhaust leak in the stock manifold that made it unbearable to drive for long distances, and 2) I wanted to put in an oxygen sensor as I will be installing an SDS and need it for tuning. (3- I always wanted headers). In wiring up the oxygen sensor and Split Second ARM-1 for monitoring, I need a switched source for power to supply the heat source for the 4 wire and the power source for the ARM-1.
Does anyone have any recommendations for the source of the switched (accessory or engine running) power I can tap into?
Thanks in advance.
I suppose it would depend on the car. From your avatar, I'm guessing you have a 280Z? Download the FSM from xenons30.com and trace the appropriate wiring diagram from the ignition switch and find one that you feel is suitable. That's what I did to power the secondary fuse box in my Z. I used the neutral safety switch (which had already been bypassed) wiring in my early 260Z.
Yeah, woops. 76 280z, manual tranny. I was thinking about the + wire to the coil, or I saw Tony had it hooked up to his fuel pump relay. I looked through the fsm and there doesn't appear to be many fused acc switched wires in the engine bay. Forgive any grammar, sending from my phone.
