R180 front pinion bearing..
Datz350
I had one fail on an long nose R200 LSD. It turned out that all the bearings were bad. Hopefully this is not the case for you.
You have to remove the carriage and pinion, hammer out the front bearing and press in a new one. I'd imagine that a shop would charge you a hundred bucks or so if you took them the differential, bearing and seal. The R200 front pinion bearing was ~$65 from Nissan.
Edited by rossman
I was thinking it would be in the hundreds.. I paid 275 for the diff... I'm thinking I got ripped off..
Yeah, I think you paid too much, assuming there it's not an LSD or something special. I've seen original long nose R180's pretty much given away on this site.
