Quick wiring question
which one? The one on the right mounted to the Black she'f is your Fusible links. All the vehicle power runs through those. The other if I remember correctly is the valves for the AC or emissions. I'd have tou look those up again. The Fusible links are ofter cut out and replaced with Maxi-fuse holders.
The LS1 swap threads should tell you what hooks up where. Go read through those a bit more, I'm sure you can find your answers in there.
Underneith that black part is the external voltage regulator for the stock alternator.
I got rid of all my fusible links . I got a fuse box from Ebay ( 2000 Malibu ) . I now have extra fuse and relay holders for my futures add-ons . This is a S130 LS1 conversion .
Haven't done it yet but this is what I'm going to do. Went to the JY and pulled an entire fusebox from a Saturn. Cost me all of $11. Of course, I'm not doing a swap or anything. I just want to get rid of that pathetic little fuse box in the center console.
