z32 case same as z33?
mike_cortes
Does anyone know if the z33 uses the same differential case as the z32 na?
Both diffs are a r200v, but i am unsure if the dimensions of the case and alignment of the side mounting tabs r the same. Visually they look the same
Im looking to swap a z32 diff in my z33 (n obviously swap over the companion flange side axles n cover so it could work)
