CLSD R200 CLUTCH INSTALL ISSUE
240z72
Hey I had a few questions about the clutchs. I found a nice PDF on the install of them wich went smooth but when I puuled my unit apart I bleive somebody already has been in here because according to the PDF im missing two spring plates. It came apart in this order 12 pices total: spacer, spring plate , plate, clutch disc, plate, spring plate, center section, spring plate, plate, clutch disc, plate, spring plae, spacer.
In the pdf file it calls for an extra spring plate at each end in stock config. Heres how it says to assemble with ne clutches.
spring disc <---missing
spring disc
clutch
plate
clutch
plate
clutch
center section
clutch
plate
clutch
plate
clutch
spring disc
spring disc<-----missing
When i removed the halfs of the diff it was under a load so it had some tention on it but I never ran this diff befor so idk if it worked. Everything looked great inside. So i dont know what to do. Just reassemble it without the 2 spring plates?
My last question would be where do i put the shims at that I need to make? It calls for 4 .004 SS shims to be about 60-75 which I want cuz it will be mostly a street car. Thnaks for your time on this in advance.
Edited by 240z7273
