Testing injectors via spinning CAS sensor
Richs72RBz
Hey guys im testing my injectors on my rb25det swap and I have a question as what to look for when testing it. I know that when you spin the CAS the injectors are suppose to click. How many times are they suppose to click? Is it suppose to cycle? Mine clicks once and does not cycle.
  • 6 months later...
I don't know if you found anything out about this problem but I am having a similar problem where mine click all at once when the CAS initially turns and then they cycle but to faintly to run the motor. Once the CAS has stopped turning for a seccond and then turned again it does the same thing. My motor fires on the initial start but won't run.
This is driving me mad that I haven't found any threads with any answeres.
