ninja240z Posted January 25, 2001 Share Posted January 25, 2001 I have both repair manuals clymer and haynes. Reading them, the two both give different info for adjusting the valves. I also suspect that the either the crank shaft pulley or the distributor is off. Previous owner had engine rebuilt by heaven only knows. Does anybody know a fool proof way to make sure of the correct position of the cam shaft lobes in relation to top dead center mark on the crank shaft and rotor pointing to #1 on the distributor? This task was alot easier on other cars that didn't have the engine rebuilt. I also would like to know if the adjusting nuts on the valves are usually very hard to turn. Thanks!!! ------------------ Here he comes, here comes speedracer! He's a demon on wheels! Quote Link to comment Share on other sites More sharing options...
ninja240z Posted January 31, 2001 Author Share Posted January 31, 2001 Talking to some experts I found out that in the history of car, somebody had replaced the oil pump without aligning it up. As a result the position of the rotor was off by one. I don't know how this car stayed running, because the distributor plug wires were at the correct position. I will probably move the wires down one. Maybe pull the oil pump and align later. ------------------ Here he comes, here comes speedracer! He's a demon on wheels! Quote Link to comment Share on other sites More sharing options...
Geno Posted January 31, 2001 Share Posted January 31, 2001 Ninja240z,glad to here you figured out your problem.I'm from Del Rio also ,how I wish I would had stayed in hot Texas .Some day I shall return. Quote Link to comment Share on other sites More sharing options...
