zercs280zx Posted March 16, 2013 Author Share Posted March 16, 2013 Thanks. I'm running fuel only with the Crane box controlling spark. I don't need to lock the dizzy in this case (MS is not controlling spark), I can advance and retard spark with the dizzy correct? I'm pretty sure about this, I just need to confirm this so I'm all set to go,. Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted March 16, 2013 Share Posted March 16, 2013 Your crane box should have a tach output which should work for MS tach input. Is the crane box controlling spark advance/retard? If not you don't have to lock to distributor. Quote Link to comment Share on other sites More sharing options...
zercs280zx Posted March 20, 2013 Author Share Posted March 20, 2013 There are 2 wires twisted together in there. Skip ahead to 1:40 to see how I wired the distributor Thanks for the visual. I'm still confused though... you are saying that you twist the red and green wires from the dizzy and connect that to the shielded Ignition in? I thought one was the trigger and one was grounded. Quote Link to comment Share on other sites More sharing options...
zercs280zx Posted March 20, 2013 Author Share Posted March 20, 2013 Your crane box should have a tach output which should work for MS tach input. Is the crane box controlling spark advance/retard? If not you don't have to lock to distributor. I was under the assumption that I could manually advance or retard the spark by adjsuting the dizzy while using the crane box. Anyone using a crane or MSD box with megasuirt? Did you have to lock the dizzy? Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted March 21, 2013 Share Posted March 21, 2013 If you want the MS to control the timing, either lock the distributor or use a crank trigger. Quote Link to comment Share on other sites More sharing options...
zercs280zx Posted April 19, 2013 Author Share Posted April 19, 2013 (edited) They're the large blue or gray boxes with little screw heads on top, in the middle of the main board. Matt, I'm just getting back to my project.... I tried to adjust the pots by turning them counter clockwise. I did not hear a pop like the msns extra write up mentioned. I made 20+ ccw turns without a click. Do you know how many ccw turns I should make? Edited April 19, 2013 by zercs280zx Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted April 22, 2013 Share Posted April 22, 2013 Depending on the part number, some of them don't really make a click. But they are generally 18 to 20 turns end to end and will not be harmed by too many turns. Quote Link to comment Share on other sites More sharing options...
