Danno74Z Posted November 22, 2012 Share Posted November 22, 2012 (edited) Back on the car after a layoff and working on the R200 Differential to Drive Shaft Connection. This topic has been discussed over the years but I figure a current review couldn't hurt. There are many ways to do this but this is the route I chose. I have a R200 from a 1989ZX with 3.54 gears with an open carrier. A few years back I went in on the group purchase and got the revised clutch carrier to make it a LSD. I also have a 1999 drive shaft from a Camaro that I will be shortening to fit the Z with the LS1/T56 combo. I will be using both yokes from that drive shaft. (One can buy the flange from JTR for $65 but I found a cheaper source, see below.) I removed the 280ZX differential flange and installed the 300ZX differential flange that I got from a wrecking yard. I had to hunt for the flange and many did not want to remove it as they wanted me to buy the entire unit. I also wanted the beefier 300ZX flange w/10mm holes and I could not find the correct 280ZX Spicer U-Joint flange to make the conversion. I had spent enough time on this and had to move-on. JTR has the flange but being a cheap SOB I went a different route. The key for me was to find the correct Spicer U-joint conversion flange and I found it at Northern Drivetrain. In the past some have used the 1819 flange but that part is now obsolete. I took a chance on the 1309 flange and it fits PERFECT to the 300ZX differential flange. Below is a picture of the assembly and a summary of the parts used. The bolts are just temporary as I will have to use 10mm socket head bolts for the final assembly. The U-joint is a conversion joint that allows one to go from Chevy to Ford components. The Chevy is a S44 U-joint and the Ford is a 1310. This stuff has been used for decades and like I said there are numerous combinations to make this connection work. I wanted to make use of the parts I already have for this build. Parts used to make the conversion: #1 38210-Y0800-300ZX Flange (Nissan) Nissan Parts Zone ($53.95) I got one from a wrecking yard #2 SPI-2-1309 Flange Yoke (Northern Drivetrain) ($34.24) #3 910-48317 U-Joint Chevy to Ford (Speedway Motors) S44/1301 conversion ($19.99) #4 1999 Chevy Drive Shaft U-joint yoke. Standard S44 joint. (Removed from drive shaft) Edited November 22, 2012 by Danno74Z Quote Link to comment Share on other sites More sharing options...
Danno74Z Posted November 29, 2012 Author Share Posted November 29, 2012 (edited) I accidentally deleted the above picture. Here it is again. Edited November 29, 2012 by Danno74Z Quote Link to comment Share on other sites More sharing options...
Danno74Z Posted November 29, 2012 Author Share Posted November 29, 2012 Here are a couple more pictures of the LSD Carrier and the bushings - 12mm to 10mm. I had to shave 1.5MM from the 10 bushings so as not to interfere with the ring gear sitting flush. Quote Link to comment Share on other sites More sharing options...
NZeder Posted December 3, 2012 Share Posted December 3, 2012 (edited) I am confused. In your post you mention the part number for the z31 diff flange as 38210-y0800 then in your next post is the image. The #1 in the image looks like 38210-10v00 to me ie the round flange with the square bolt pattern--- see here for info on the 2 type of z31 driveshaft and diff flange setup. http://www.xenonz31....eshaftinfo.html Edited December 3, 2012 by NZeder Quote Link to comment Share on other sites More sharing options...
