Fuel Cell Questions....
HarveyZ
I have a 260z with a 400 small block. It currently has the stock tank. I have been losing gas for a while now if I put too much gas in or take a curve too sharp. Now that the car is no longer my daily driver I dropped the tank and discovered it has some small rust holes in the top of the tank. Instead of buying another stock tank I would like to go with a 16 gal. fuel cell. This way i can run dual exhaust and have bigger fuel lines. I know I have to cut the spare tire well out and fab a tank support up but what else is needed?? Right now it has the stock sending unit. I need an in-line fuel pump instead of the stock sending unit, right... Anything else???
I live 10 minutes from the drag strip so the car will see more of the strip than anything. Might take it down the road sometimes on the weekends. I want around 400-450hp out of the car
