MS 2 V 3.57 spark table inop
skirkland1980
Running ms 2 v 3.57 on 1983 280zx L28E. It has the stock vr distributor with a single coil. Has low impedance 440cc injectors (2.0 ohms each). All ms grounds to the battery negative, sensors ground to the intake manifold. I have a toggle switch to the battery to power ms. Everything is fused and relayed. I'm not having much problem anymore with the box getting hot and the engine misfiring that I've noticed. The main problem I'm concerned with now is ms isn't following the spark table. IGN is soldered to pin 7 of the 40 pin dip socket to a 330 ohm resistor to the bip373. Thanks
2012-12-22_14.52.45.zipFetching info...
amanda 2012-09-06_19.13.10.zipFetching info...
  On 1/6/2013 at 12:32 AM, skirkland1980 said:
The timing stays steady after I try to change it with trigger wizard. When I adjust with the wizard I get 0* or 30*.
Confusing post to me.  For clarification to the guys, when you set trigger wizard to 30, does your timing light stay at 30?  And when you set trigger wizard to 0 your timing light stays at 0.
