Ignition decisions...
RyuZ32
I just got an MSD box for my birthday, and I am currently in the process of building my turbo 280Z. If I install this MSD box, would I be able to switch to the Ford EDIS system and still use the MSD? Or does the EDIS make the use of the MSD useless?
Current setup in the works
N42 Block
P90 head
N42 Non-EGR manifold
240sx TB
Megasquirt 2 with/innovate wideband
Also do I wire the MSD in to the Megasquirt?
The MSD and EDIS are not likely to play well together, and
largely pointless, as some (most?) EDIS modules appear to
have built-in multispark functionality.  I won't say it cannot be
done, but it would not be a simple splice in wiring job.
The MS2 and MSD with a single coil/dizzy setup would be
fine.
If you do use the gift MSD, it would be a good idea to wire
it up with the MS to give you control of your ignition timing,
If you go the EDIS route make sure to find another visible
project to use the thoughtful MSD gift on.
